Please note that the below configuration is intended for testing purposes only. Make sure that your final deployment is within your business security policies.
The installation guide can be found at: http://support.ptc.com/WCMS/files/173161/en/ThingWorxDockerInstaller.pdf
Postgres:
Docker:
Thingworx Installation:
Installation Directory: C:\Program Files (x86)\twxEnterpriseFoundationPostgresDocker
ThingWorx License Directory: C:\Users\Administrator\Desktop\license.bin
Local ThingWorx Foundation Port: 8080
Java Initial Heap setting for TWX Foundation: 1024
Java Max Heap setting for TWX Foundation: 2048
RDS Instance: 1
PostgreSQL Host: 10.0.75.1
PostgreSQL Port: 5432
PostgreSQL Admin Schema: postgres
PostgreSQL Admin Username: postgres
PostgreSQL Admin Password: <see note>
PostgreSQL ThingWorx Foundation Schema: thingworx
PostgreSQL ThingWorx Foundation Username: thingworx
PostgreSQL ThingWorx Foundation Password: <see note>
PostgreSQL ThingWorx Tablespace Location: /
NOTE: It is highly recommended to use a complex password (Letters of all cases, numbers, and symbols) as we have opened up our database to remote connections
Post Install:
Troubleshooting:
Hi Tony,
I installed Thingworx on centos 7 with Docker installation package in a vm.
My issue is that I could not setup the bridge connection with docker.
When I followed your instruction,
https://community.thingworx.com/servlet/JiveServlet/showImage/38-1476-6261/HyperV.jpg
You have this option, but it's gray and could not be clicked in my virtual machine.
Could you give some suggestions?
Br,
Anna
Hi Anna An,
Make sure the VM is powered down, and that should allow you to make the changes.
Tony
Hi Tony,
Yes it worked after powering off the VM:)
Hi Tony,
Thanks for detailed info.
Actually, i am trying to setup Thingworx 8.0 docker setup in ubuntu 14.
I setup docker and installed postgreSQL as well.
When i trying to execute thingworx installer file then i am getting error
Warning: Problem running post-install step. Installation may not complete
correctly
Error running ./check-http-response.linux -username "Administrator" -password
"trUf6yuz2?_Gub" -hostname "127.0.1.1" -hostport "8080": child process exited
abnormally
again i tried then i got below error:
Installing
0% ______________ 50% ______________ 100%
#######################################Warning: Problem running post-install step. Installation may not complete
correctly
Error running docker run -it -d -l TWX -p 8080:8080 -v
"/opt/twxEnterpriseFoundationPostgresDocker/license:/app" -v
ThingworxFoundationPostgres:/ThingworxPlatform -v
ThingworxFoundationPostgresStorage:/ThingworxStorage -v
ThingworxFoundationPostgresBackupStorage:/ThingworxBackupStorage --name
twxfoundation -e INITIAL_HEAP=1024 -e MAX_HEAP=2048
installer/twx/thingworx-enterprise-foundation-postgres:8.0.2-b67 -D 172.17.0.1
-q 5432 -U postgres -P postgres1 -S postgres -u twadmin -p password -s thingworx
-t /opt/postgres/tablespaces/thingworx -r 0: docker: Error response from daemon:
Conflict. The container name "/twxfoundation" is already in use by container
"6d2920f2f533d15f358153561f998a11b5815c7aca0a52400e064e6734218456". You have to
remove (or rename) that container to be able to reuse that name.
See 'docker run --help'.
Press [Enter] to continue:
Do you have any idea about that? although i know you tried on window machine
Hi Varun,
When you did the first install, did you do 127.0.0.1 for the PostgreSQL Host? And then the second time around do 172.17.0.1?
There are some cleanup steps that need to be done before attempting to do another install. Try going through this (http://support.ptc.com/WCMS/files/173161/en/ThingWorxDockerInstaller.pdf#page=35) and that should prevent that second error from appearing.
Tony
Hi Tony,
Thanks for reply. Yes, did same on first instance but now I not doing that .Now i am using fresh VM machine and giving postgres host as docker IP (172.17.0.1) . Still i am getting permission denied issue in the docker container logs.
When is saw the container logs i found below logs
root@varun-VirtualBox:/home/varun# docker logs twxfoundation1
New license found in /app, installing: license.bin
172.17.0.1
5432
postgres
postgres
postgres
twiadmin
twiadmin
thingworxx
/opt/ThingworxPostgresqlStorage
no
*:*:postgres:postgres:postgres
*:*:thingworxx:twiadmin:twiadmin
No database found, creating new database
CREATE ROLE
NOT an RDS Instance
/opt/tomcat/webapps/install/thingworx-database-setup.sql: Permission denied
psql: FATAL: database "thingworxx" does not exist
Using CATALINA_BASE: /opt/tomcat
Using CATALINA_HOME: /opt/tomcat
Using CATALINA_TMPDIR: /opt/tomcat/temp
Using JRE_HOME: /opt/jdk1.8.0_92
Using CLASSPATH: /opt/tomcat/bin/bootstrap.jar:/opt/tomcat/bin/tomcat-juli.jar
Java HotSpot(TM) 64-Bit Server VM warning: Cannot open file /opt/tomcat/logs/tomcat-twx-gc.log due to Permission denied
java.util.logging.ErrorManager: 4
java.io.FileNotFoundException: /opt/tomcat/logs/catalina.2017-08-09.log (Permission denied)
and then i get into docker container with "docker exec -it name-of-container bash" command , i found:
twadmin@711516e559a9:/opt/tomcat/webapps$ ls -lrt
ls: cannot access 'ROOT': Permission denied
ls: cannot access 'Thingworx': Permission denied
ls: cannot access 'install': Permission denied
ls: cannot access 'update': Permission denied
ls: cannot access 'examples': Permission denied
ls: cannot access 'host-manager': Permission denied
ls: cannot access 'docs': Permission denied
total 4
d????????? ? ? ? ? ? update
d????????? ? ? ? ? ? install
d????????? ? ? ? ? ? host-manager
d????????? ? ? ? ? ? examples
d????????? ? ? ? ? ? docs
d????????? ? ? ? ? ? Thingworx
d????????? ? ? ? ? ? ROOT
-rw-rw-r-- 1 twadmin twadmin 242 Jul 31 15:32 platform-settings.json
