This post adds to my previous post: Deploying H2 Docker versions quickly
In addition to configuring the basic Docker Images and Containers, it's also possible to deploy them with a TLS / SSL certificate and access the instances via HTTPS protocol.
For this a valid certificate is required inside a .jks keystore. I'm using a self-signed certificate, but commercial ones are even better! The certificate must be in the name of the machine which runs Docker and which is accessed by the users via browser. In my case this is "mne-docker". The password for the keystore and the private key must be the same - this is a Tomcat limitation. In my case it's super secret and "Password123456".
I have the following directory structure on my Operating System
The Recipe File
In the Recipe File I make sure that I create a new Connector on port 8443, removing the old one on port 8080.
I do this by just replacing via the sed command - also introducing options for content compression.
I'm only replacing the first line of the xml node as it holds all the information I need to change.
Changes to the original version I posted are in green
FROM tomcat:latest MAINTAINER mneumann@ptc.com LABEL version = "8.2.0" LABEL database = "H2" RUN mkdir -p /cert RUN mkdir -p /ThingworxPlatform RUN mkdir -p /ThingworxStorage RUN mkdir -p /ThingworxBackupStorage ENV LANG=C.UTF-8 ENV JAVA_OPTS="-server -d64 -Djava.awt.headless=true -Djava.net.preferIPv4Stack=true -Dfile.encoding=UTF-8 -Duser.timezone=GMT -XX:+UseNUMA -XX:+UseG1GC -Djava.library.path=/usr/local/tomcat/webapps/Thingworx/WEB-INF/extensions RUN sed -i 's/<Connector port="8080" protocol="HTTP\/1.1"/<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol" maxThreads="150" SSLEnabled="true" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" enableLookups="false" keystoreFile="\/cert\/mne-docker.jks" keystorePass="Password123456" ciphers="TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256, TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256, TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_128_CBC_SHA" compression="on" compressableMimeType="text\/html,text\/xml,text\/plain,text\/css,text\/javascript,application\/javascript,application\/json"/g' /usr/local/tomcat/conf/server.xml COPY Thingworx.war /usr/local/tomcat/webapps VOLUME ["/ThingworxPlatform", "/ThingworxStorage", "/cert"] EXPOSE 8443
Note that I also map the /cert directory to the outside, so all of my Containers can access the same certificate. I will access it read-only.
Deploying
sudo docker build -t twx.8.2.x.h2 . sudo docker run -d --name=twx.8.2.x.h2 -p 88:8443 -v /home/ts/docker/twx.8.2.x.h2/storage:/ThingworxStorage -v /home/ts/docker/twx.8.2.x.h2/settings:/ThingworxPlatform -v /home/ts/docker/certificates:/cert:ro twx.8.2.x.h2
Mapping to the 8443 port ensures to only allow HTTPS connections.
The :ro in the directory mapping ensures read-only access.
What next
Go ahead! Only secure stuff is kind of secure 😉
For more information on how to import the certificate into a the Windows Certificate Manager so browsers recognize it, see also the Trusting the Root CA chapter in Trust & Encryption - Hands On
