End to end Integration of Kepware to ThingWorx using MQTT over Azure IoT
100% helpful (1/1)
I've had a lot of questions over the years working with Azure IoT, Kepware, and ThingWorx that I really struggled getting answers to. I was always grateful when someone took the time to help me understand, and now it is time to repay the favour.
People ask me many things about Azure (in a ThingWorx context), and one of the common ones has been about MQTT communications from Kepware to ThingWorx using IoT Hub. Recently the topic has come up again as more and more of the ThingWorx expert community start to work with Azure IoT. Today, I took the time to build, test, validate, and share an approach and utilities to do this in cases where the Azure Industrial IoT OPC UA integration is overkill or simply a step later in the project plan. Enjoy!
End to end Integration of Kepware to ThingWorx using MQTT over Azure IoT (YoutTube 45 minute deep-dive)
ThingWorx entities for import (ThingWorx 9.0)
This approach can be quite good for a simple demo if you have a Kepware Integrator or Kepware Enterprise license, but the use of IoT Gateway for many servers and tags can be quite costly.
Those looking to leverage Azure IoT Hub for MQTT integration to ThingWorx would likely also find this recorded session and shared utilities quite helpful.
Cheers,
Greg
