Security Alert Log4j Security Vulnerability. Click here to know more.
Find an existing Expression Rule and apply it to an asset
nishanair
This script finds an existing Expression Rule and applies it to an asset (via asset includes).
Parameters:
  1. model - model name
  2. serial - serial number
  3. exprRuleName - name of the Expression Rule
import static com.axeda.sdk.v2.dsl.Bridges.*
import net.sf.json.JSONObject
import com.axeda.drm.sdk.scripto.Request
import com.axeda.services.v2.Asset
import com.axeda.services.v2.AssetReference
import com.axeda.services.v2.AssetCollection
import com.axeda.services.v2.AssetCriteria
import com.axeda.services.v2.ExpressionRule
import com.axeda.services.v2.ExpressionRuleCriteria
* ApplyExpRuleToAsset.groovy
* Finds an existing Expression Rule and includes an asset into it.
* @param model        -   (REQ):Str model of the asset.
* @param serial        -   (REQ):Str serial number of the asset.
* @param exprRuleName        -   (REQ):Str name of the Expression Rule.
* @author Sara Streeter <sstreeter@axeda.com>
def response = [:]
def root = [:]
try {
   AssetCriteria assetCriteria = new AssetCriteria()
   assetCriteria.modelNumber = Request.parameters.model
   assetCriteria.serialNumber = Request.parameters.serial
   def findAssetResult = assetBridge.find(assetCriteria)
   def asset = findAssetResult.assets[0]
   ExpressionRuleCriteria expressionRuleCriteria = new ExpressionRuleCriteria()
   expressionRuleCriteria.name = Request.parameters.exprRuleName
   def expressionRuleFindResult = expressionRuleBridge.find(expressionRuleCriteria)
   def expressionRule = expressionRuleFindResult.expressionRules[0]
  def expAssets =  expressionRule.includedAssets.add(asset)
  expressionRuleBridge.update(expressionRule)
  response = [
      "expressionRule":expressionRule.name,
      "includedAsset": asset.serialNumber
} catch (Exception e) {
     response = [
            faultcode: 'Groovy Exception',
            faultstring: e.message
return ["Content-Type": "application/json","Content":JSONObject.fromObject(response).toString(2)]
0 REPLIES 0
