Question: What is the best way to use Git with ThingWorx?
After the release of ThingWorx 8.4 two weeks ago, are you looking for even more? Can’t get enough of ThingWorx? Good thing—because we’ve got you covered.
We have just released Version 2.0 of the ThingWorx Git Backup Extension!
In the newest version, you’ll find:
If you’re looking for guidance on how to configure Git with ThingWorx, check out one of my earlier posts that explains how you can use Git to achieve continuous integration with ThingWorx or view the updated Git Backup Extension User Guide attached (see the “Attachments” section to the right).
Shoutouts to Vladimir, Gabriel, Bogdan, Moritz and Pierre for making this available.
Let me know what you think of Version 2.0 in the comments below!
Stay connected,
Kaya
When I imported the extension, the import was successful however the NewTab Entity is missing from the import.
Therefore making this extension unusable.
Same problem here ....
the thing "NewTab" is missing in the extension
Hey guys,
Sorry about this issue. This is a known extension bug manifesting only in ThingWorx 8.4. We're working to fix this asap. As a workaround please use the previous version, 1.3.1.
Note: the Extension was tested in 8.3.3 and 8.2.3. Anything minor in those versions should work fine.
The issue should be solved. Please test and let us know if the issue is solved (restart the server after extension import).
You can download the fix by searching for the 2.0.1 version of the Git Backup Extension in the PTC Marketplace.
Thanks!
I tried to go the the download link, but I got a 404! Is it taken down?
Thanks! The original link is still down, maybe it is a problem in the USA or something.
Thanks @k_ibrahem for bringing this up and @VladimirRosu for your help. I have updated the link in the post.
Why are only FileRepositories, and not SourceControlRepositories supported by the extension? I thougth that seperate SourceControlRepositories are more secure since FileRepositories are also exposed to the web with download links ? Wouldn't it be good to make it possible for this extension to use SourceControlRepositories as well ?
