When predicting a Boolean goal such as Failure in the next hour or any other goal that has a yes or no answer, Thingworx Analytics(TWXA) models will output a 'risk' of the event occurring. TWXA will intelligently pick a threshold beyond which that risk warrants attention.
1. In Analytics Builder, click on the export button
2. This will export a PMML model and download it for you
3. Open up the PMML model, in the output section, you will find a condition that explains the threshold that was selected by TWX Analytics.
In this example case, TWXA chose 0.5 as the best Threshold.
Note: The export button will only be available in Builder for TWXA 8.4+.
Hi @rkhadilkar
Thank you for sharing this.
For users on older versions, they can follow the information in this article to find the threshold use and how to export the pmml: https://www.ptc.com/en/support/article?n=CS295008
Kind rgeards
Christophe
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
