How to re-install ThingWorx Flow which is failing with the SystemCallError error? (Windows Only)
vangne
Suppose, if you have uninstalled ThingWorx Flow successfully with appropriate steps. And, tried re-installing which is failing with below error in the flow installation logs,
" FATAL: SystemCallError: windows_service[RabbitMQ] (orchestration::rabbitmq line 120) had an error: SystemCallError: The specified service does not exist as an installed service. - OpenService: The specified service does not exist as an installed service."
This is due to the registry problem.
To resolve this, need to delete the registry key. Following steps are need to be performed:
  1. Go to Start-> Search and Run 'regedit' as an Administrator
  2. Navigate to 'Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Ericsson'
  3. Delete Ericsson key and its sub key
  4. Restart your machine
  5. Install ThingWorx Flow again and it will be successful.
Here is the article link on this subject: https://www.ptc.com/en/support/article/CS328600
Vibhuti Angne
0 REPLIES 0
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
