IOT EDC Reference Benchmark - New Scenario Using Multi-Kepware for Connected Factories
ttielebein
for Asset Monitoring in Connected Factories
A new scenario has been completed for Connected Factory implementations, furthering the IOT EDC's goal of providing a reference library of ThingWorx performance. This scenario builds upon the first, with additional tests being performed to demonstrate the capabilities of multiple Kepware Servers running side-by-side. Horizontal scaling is very common for multi-line factory implementations, so be sure to check out the new scenario in this ever-expanding benchmark document.scenario2.jpg
Note that tests below 10,000 writes per second were not repeated with multiple Kepware Servers, since there is little reason to desire such a configuration in implementations that small. ThingWorx deployment sizing was also held constant throughout these tests to demonstrate the limits of a given configuration. Changes that may improve the results of a failed test (such as adding CPUs or Memory) will be mentioned but not validated as part of this benchmark.
Let us know about your applications and how they compare with the data shared here. Happy developing!
0 REPLIES 0
