Installing an Open Source Time Series Platform
For testing InfluxDB and its graphical user interface, Chronograf I'm using Docker images for easy deployment. For this post I assume you have worked with Docker before.
In this setup, InfluxDB and Chronograf will share an internal docker network to exchange data.
The following commands can be used to create a InfluxDB environment.
Pull images
sudo docker pull influxdb:latest sudo docker pull chronograf:latest
Create a virtual network
sudo docker network create influxdb
Start the containers
sudo docker run -d --name=influxdb -p 8086:8086 --net=influxdb --restart=always influxdb sudo docker run -d --name=chronograf -p 8888:8888 --net=influxdb --restart=always chronograf --influxdb-url=http://influxdb:8086
InfluxDB should now be reachable and will also restart automatically when Docker (or the Operating System) are restarted.
Content Move Notice (Dec. 2018)
ThingWorx Code Examples boards are now merged into IoT Tech Tips under the Code Examples label.
The Service Apps board is now merged into the Manufacturing Apps board.
