Installing ThingWorx Analytics 8.3
Re: Installing ThingWorx Analytics 8.3
I have installed the thingworx analytics in which descriptive analytics was not installed. Then I followed the installation manual pdf and then  I am unable to proceed due to this error.tw_twas.sh.pngAfter running the twas.sh commandAnalyticsServer_error.pngRetrieveAnalyticsServers service error
please guide on how to proceed forward.
Hi @akaditya6896
The installation guide states:
For example: /opt/ThingWorxAnalytics/ThingWorxAnalyticsServer/bin/twas.sh status
which indicates that the twas.sh script is in the bin folder not the standalone_jars one.
If you change directory to <ThingWorxAnalytcisServer>/bin you should be able to find it.
Also, as mentioned before please open a  new discussion in the Community or a case to Technical Support if you face issue.
Thank you
Kind regards
Christophe
