Installing ThingWorx Analytics Server 52.x - part 2 - end
Highlighted
Tanzanite
In this video we cover the process of installing ThingWorx Analytics Server 52.1.
Make sure to have reviewed the part 1 video about pre requisite
Updated Link for access to this video:  Installing ThingWorx Analytics Server: Part 2 of 2
4 REPLIES 4
Highlighted
Re: Installing ThingWorx Analytics Server 52.x - part 2 - end
Hi Chris,
I have been following your video tutorial and I ran into problem with finishing the build of the virtual machine. I have attached the error when building for virtualbox. It seems as though the virtual machine is not closing gracefully. After this error is thrown, the vm built up to this point is deleted. I am running a windows 10 64 bit machine if that makes a difference.
Matt
Highlighted
Hi Matt
I would recommend you check this article https://support.ptc.com/appserver/cs/view/solution.jsp?n=cs247611 which covers this exact error message.
That should help you move forward.
Should you still face issue, do not hesitate to open a case to Technical Support so this can be looked at in more details.
Kind Regards
Christophe
Highlighted
Hi Christophe,
Where can I find the next part of this video series?
Simon
Highlighted
Hi Simon
This series of video focuses on the installation of ThingWorx Analytics Server and is made of 2 videos.
This one is the second and last of the series. The first video can be found at part 1 video .
We are also working on some more videos regarding using ThingWorx Analytics Server but they are not yet complete at this time.
Kind regards
Christophe
