Installing Thingworx Analytics Builder part 3 of 3
cmorfin
Tanzanite
In this video we cover the installation of the UploadThing module.
This video applies to ThingWorx Analytics 52.2 till 8.0. This is no longer applicable with ThingWorx Analytics 8.1
Useful links:
Updated Link for access to this video:  Installing Thingworx Analytics Builder: Part 3 of 3
Re: Installing Thingworx Analytics Builder part 3 of 3
I am trying to install the UploadThing on Ubuntu Server 14.04.5 LTS
UploadThing_Install-52-2.zip
This is the errors I get:
duan@ubuntu:/tmp$ sudo sh ./install.sh
-en
Checking java version...
-e OK
Where do you want to install 'UploadThing' [/opt]?
./install.sh: 1: ./install.sh: Bad substitution
./install.sh: 142: [: ==: unexpected operator
sudo: chkconfig: command not found
/etc/init.d/UploadThing: line 8: /etc/rc.d/init.d/functions: No such file or directory
Starting UploadThing: /etc/init.d/UploadThing: line 19: runuser: command not found
touch: cannot touch ‘/var/lock/subsys/UploadThing’: No such file or directory
/etc/init.d/UploadThing: line 23: success: command not found
The script seems to be targeted specifically at Centos and seems incompatible with Ubuntu.
I would appreciate any help.
Hi Duan
Can you try using the script from https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS246768 ?
Kind regards
Christophe
Thanks for the link Christophe,
This is the content of the updated install.sh:
#!/bin/sh
version=1.0
uploadThingDir=/opt/UploadThing-${version}
if [ ! -f ${uploadThingDir}/bin/UploadThing ]
then
    uploaddir=
    while [ -z $uploaddir ]
    do
        read -p "Where is the 'UploadThing' installed [/opt]? " uploaddir
        if [ -z $uploaddir ]
        then
            uploaddir="/opt"
        fi
        uploadThingDir=${uploaddir}/UploadThing-${version}
        then
            echo -e "\n****  This is not where 'UploadThing' is installed, try again\n"
            uploaddir=
        fi
    done
fi
cat UploadThing.ori | sed -e "s|::uploaddir::|${uploadThingDir}|g" > UploadThing
cp UploadThing /etc/init.d
chmod 755 /etc/init.d/UploadThing
chkconfig UploadThing on
service UploadThing start
Unfortunately it seems it is not compatible with Ubuntu 14.04.5
./install.sh: 28: ./install.sh: chkconfig: not found
Starting UploadThing: touch: cannot touch ‘/var/lock/subsys/UploadThing’: No such file or directory
/etc/init.d/UploadThing: line 17: runuser: command not found
/etc/init.d/UploadThing: line 21: success: command not found
As far as I can tell the problem lies with chkconfig:
My research shows:
The command chkconfig is no longer available in Ubuntu.The equivalent command to chkconfig is update-rc.d.This command nearly supports all the new versions of ubuntu.
The similar commands are
update-rc.d <service> defaults update-rc.d <service> start 20 3 4 5 update-rc.d -f <service>  remove
Hi Duan
Thank you for the feedback.
Then it would seem there is indeed an issue on Ubuntu newer releases.
I am checking on this and will update you when I get more information
Christophe
Hi Duan
I have reported this to R&D as the install script does not work indeed on latest release of Ubuntu.
You can find more details at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS257078 .
For now one way around it is to Create, configure and Upload the dataset through REST API, then use ThingWorx Analytics Builder to manage the uploaded dataset.
Kind regards
Christophe
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
