This Guide contains all the Linux commands that you may have to use for ThingWorx Analytics Installation or day to day use.
Command/Category | Description |
Network/port | |
ip a | List the ips of all of the network interfaces |
ssh | How to jump from one machine to another |
ping | Send packets to a remote machine. useful for testing connectivity |
netstat –anp | Check active port |
cat < /dev/tcp/localhost/8080 | Test connection to a port Replace localhost with desired hostname or ip, replace 8080 with desired port number (/dev/tcp/host/port) |
exit | Exit my current sign in. this lets one disconnect from remove ssh sessions or if one has changed one's user e.g. switched to root |
scp | Retrieve something via ssh |
Resource Usage | |
free -m | Check memory -m is for output in Mb |
Mpstat -P ALL | CPU usage |
top | Process usage |
jvmtop | Collect cpu usage of jvm and its thread https://github.com/patric-r/jvmtop (requires jdk to be installed) |
File Interaction | |
cp / mv | Copy and move respectively. mv just deletes the source file. Usage: cp /source/location/file /output/location/file |
cat |
vim / vi | A command line text editor. Not the most user friendly (none of them are) but really useful. Here's a cheat sheet for the commands https://www.fprintf.net/vimCheatSheet.html |
rm | Remove files |
chmod | Change the access permissions of files |
chown | Change the user or group ownership of files |
grep | A text based filtering. Useful for making a larger list smaller and more targeted. Almost always used after a pipe (see pipe below) |
less | Generally used to view the contents of a file with more friendly scrolling |
locate | Find a file by name |
Directory | |
ls | What’s in the directory. Will do the current directory but you can also pass the directory e.g. ls /var/log/tomcat.
pwd | Tell me which directory I'm currently in |
cd | Change directory. provide the directory to change to or just use cd to return to the user's home directory |
clear | Clears the screen Terminal clears all provided commands |
mkdir | Creates Directories |
Running Processes | |
ps | Query what services are running. usually use ps -aux to get a full, sorted list. using grep with this is helpful |
systemctl | The correct way to interact with services that are running |
Package installation | |
yum install <packageName> | Install a package. More useful commands: https://www.centos.org/docs/5/html/5.1/Deployment_Guide/s1-yum-useful-commands.html |
yum list installed | List installed packages |
yum list <package> | List available packages |
yum --showduplicates list java-1.7.0-openjdk-devel | Use --showduplicates to see all versions Can use * for package name: *openjdk* |
rpm -ql <packagename> | Find where package are installed Note: works if package installed with yum |
Yumdownloader --urls <packageName> | Find URL where a package is downloaded from. Note: need to install yum-utils package |
Repoquery --requires <packageName> | Find dependencies of a package Note: need to install yum-utils package |
repoquery --qf=%{name} -g --list --grouppkgs=all [groups] | xargs repotrack -a x86_64 -p /repos/Packages | Download a package with all its dependencies. Need to install yum-utils package From <http://unix.stackexchange.com/questions/50642/download-all-dependencies-with-yumdownloader-even-if-already-installed> |
Other Commands | |
Send REST call via command line Use -X POST (default GET) for a POST (see man page - https://curl.haxx.se/docs/manual.html for example) See also http://www.codingpedia.org/ama/how-to-test-a-rest-api-from-command-line-with-curl/ | |
Find / -type f -exec grep -I mystring {} \; | Search string in files |
Sudo -u user command | Execute a command as different user |
The below helpers are not commands themselves, but can be used in conjunction with the above commands.
Helper | Description |
'pipe' | The | character. lets one chain commands. e.g. ps -aux | grep java |
./ | The shorthand way to refer to this directory explicitly |
../ | The shorthand way to refer to the parent directory |
'tab completion' | Pressing tab will let linux guess what command/option best fits what's currently written. very useful for navigating directories and long-named files (NOTE: not necessarily tab based upon one's keyboard layout/language) |
'ctrl-r' | Look up the mostly likely command that matches what one typing. so if one earlier used ps -aux | grep java | less and the hit ctrl-r and typed -aux it would likely pull that command or at least the most recent one that matches |
