Linux Commands Quick Guide
No ratings
This Guide contains all the Linux commands that you may have to use for ThingWorx Analytics Installation or day to day use.
Command/Category
Description
Network/port
ip a
List the ips of all of the network interfaces
ssh
How to jump from one machine to another
ping
Send packets to a remote machine.  useful for testing connectivity
netstat –anp
Check active port
cat < /dev/tcp/localhost/8080
Test connection to a port
Replace localhost with desired hostname or ip, replace 8080 with desired port number
(/dev/tcp/host/port)
exit
Exit my current sign in.  this lets one disconnect from remove ssh sessions or if one has changed one's user e.g. switched to root
scp
Retrieve something via ssh
Resource Usage
free -m
Check memory
-m is for output in Mb
Mpstat -P ALL
CPU usage
top
Process usage
jvmtop
Collect cpu usage of jvm and its thread
https://github.com/patric-r/jvmtop
(requires jdk to be installed)
File Interaction
cp / mv
Copy and move respectively. mv just deletes the source file.  Usage: cp /source/location/file /output/location/file
cat
  1. Mostly used to just print the contents of a file to the command line.  can also print multiple files at once:  cat /var/log/gridworker/warning.log /var/log/gridworker/error.log
vim / vi
A command line text editor. Not the most user friendly (none of them are) but really useful. Here's a cheat sheet for the commands https://www.fprintf.net/vimCheatSheet.html
rm
Remove files
chmod
Change the access permissions of files
chown
Change the user or group ownership of files
grep
A text based filtering.  Useful for making a larger list smaller and more targeted.  Almost always used after a pipe (see pipe below)
less
Generally used to view the contents of a file with more friendly scrolling
locate
Find a file by name
Directory
ls
What’s in the directory.  Will do the current directory but you can also pass the directory e.g. ls /var/log/tomcat.
  • Black writing is files
  • Blue writing is directories
  • Red writing is compressed file
pwd
Tell me which directory I'm currently in
cd
Change directory.  provide the directory to change to or just use cd to return to the user's home directory
clear
Clears the screen Terminal clears all provided commands
mkdir
Creates Directories
Running Processes
ps
Query what services are running. usually use ps -aux to get a full, sorted list.  using grep with this is helpful
systemctl
The correct way to interact with services that are running
Package installation
yum install <packageName>
Install a package. More useful commands: https://www.centos.org/docs/5/html/5.1/Deployment_Guide/s1-yum-useful-commands.html
yum list installed
List installed packages
yum list <package>
List available packages
yum --showduplicates list java-1.7.0-openjdk-devel
Use --showduplicates to see all versions
Can use * for package name: *openjdk*
rpm -ql <packagename>
Find where package are installed
Note: works if package installed with yum
Yumdownloader --urls <packageName>
Find URL where a package is downloaded from.
Note: need to install yum-utils package
Repoquery --requires <packageName>
Find dependencies of a package
repoquery --qf=%{name} -g --list --grouppkgs=all [groups] | xargs repotrack -a x86_64 -p /repos/Packages
Download a package with all its dependencies. Need to install yum-utils package From  <http://unix.stackexchange.com/questions/50642/download-all-dependencies-with-yumdownloader-even-if-already-installed>
Other Commands
curl http://localhost:8080/1.0/about/versioninfo
Send REST call via command line
Use -X POST (default GET) for a POST (see man
page - https://curl.haxx.se/docs/manual.html for example)
See also http://www.codingpedia.org/ama/how-to-test-a-rest-api-from-command-line-with-curl/
Find / -type f -exec grep -I mystring {} \;
Search string in files
Sudo -u user command
Execute a command as different user
The below helpers are not commands themselves, but can be used in conjunction with the above commands.
Helper
Description
'pipe'
The | character.  lets one chain commands.  e.g. ps -aux | grep java
The shorthand way to refer to this directory explicitly
The shorthand way to refer to the parent directory
'tab completion'
Pressing tab will let linux guess what command/option best fits what's currently written.  very useful for navigating directories and long-named files (NOTE: not necessarily tab based upon one's keyboard layout/language)
'ctrl-r'
Look up the mostly likely command that matches what one typing.  so if one earlier used ps -aux | grep java | less and the hit ctrl-r and typed -aux it would likely pull that command or at least the most recent one that matches
Version history
Last update:
‎Aug 30, 2016 10:50 AM
Updated by:
Labels (1)
