Live Webinar on June 22nd 11am EST: 5 Common Mistakes for Developing Scalable IoT Applications
No ratings
We will host a live Expert Session: "5 Common Mistakes for Developing Scalable IoT Applications" on June 22nd, 11h00 EST.
Please find below the description of the expert session and the registration link.
Expert Session: 5 Common Mistakes for Developing Scalable IoT Applications
Date and Time: June 22nd, 11h00 EST
Duration: 1 hour
Host: Tori Firewind, Mike Jasperson and Prachi Rath - Enterprise Deployment Center
Registration Here: https://www.ptc.com/en/resources/iiot/webcast/5-common-dev-mistakes-for-scalable-iot-applications
Description:
To build scalable applications, it’s necessary to identify the common mistakes made and ensure to avoid them at the early stages of development.
In this expert session, the PTC Enterprise Deployment Team will elaborate on why scalability is important and how one can avoid the common development pitfalls in IoT.
Existing Recorded sessions can be found on support portal using the keyword ‘Expert Sessions’.
You can also suggest topics for upcoming sessions using this small form.
Here are some recorded sessions that might be of your interest. You can find recordings for the full library of webinars using the keyword ‘Expert Sessions’ in PTC support portal search
Thingworx Active Active Clustering
This session will cover the main aspects of the High Availability Clustering feature launched with the ThingWorx 9.0 release.
Recoding Link
Upgrade to Thingworx 9 – How to Plan / Evaluate Impacts
This session highlights the key points you should evaluate to properly plan your upgrade to Thingworx 9.
Recording Link
Top 5 items to check for Thingworx Performance Troubleshooting
How to troubleshoot performance issues in a Thingworx Environment? Here we cover the top 5 investigation steps that will help you understand the source of your environment issues and allow better communication with PTC Technical Support
Recording Link
Version history
Last update:
‎Jun 17, 2021 02:08 PM
Updated by:
Labels (2)
