Mapping previous versions of ThingWorx Analytics API to ThingWorx Analytics 8.1 Services
No ratings
Since ThingWorx Analytics 8.1, the classic server monolith has been replaced by a series of independent microservices. This new structure groups services around specific elements of functionality (data, training, results). Thus the use of the previous API commands to access ThingWorx Analytics functions has been replaced by the use of ThingWorx Services. Those Services exist within specific Microservice Things accessible in the ThingWorx Platform 8.1.
The table below shows a mapping of the most common previous API commands from version 8.0 and previous versions to the version 8.1 related services. The table below does not contain an exhaustive listing either of API commands nor of Services.
The API commands used below are samples which might require further information like headers and Body once used. These are used in the table below for reference purposes.
Previous API Command Purpose
Sample Syntax
TWA 8.1 Service
Analytics Thing related to Service
Service description
1
Version Info
GET: http://<IP Address>:8080/1.0/about/versioninfo
VersionInfo
This service is available in each Mircorservice Thing inheriting from Analytics Server
Returns the internal
version number for a
specific microservice.
The first two digits =
ThingWorx Core
  • version. The next three
digits = version of the
  1. microservice.
2
Registering new Dataset
POST: http://<IP Address>:8080/1.0/datasets/
CreateDataset
Data Microservice
Creates the dataset uploads the data along with its metadata and
optimizes it
  1. automatically.
3
Checking Dataset Status
GET: http://<IP Address>:8080/1.0/datasets/<DataSet Name>
ListCreatedDatasets
Data Microservice
This old functionality is replaced by a Service that lists all the created Datasets
4
Creating Metadata
POST: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/configuration
CreateDataset
Data Microservice
(Check line 2 for further information)
5
Checking Dataset Configuration
GET: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/configuration
GetDatasetSchema
Data Microservice
Retrieves the metadata
from a dataset.
6
Loading Dataset CSV
POST: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/data
CreateDataset
Data Microservice
7
Checking Job Status
GET: http://<IP Address>:8080/1.0/status/<Job ID>
GetJobStatus
Available in all created Microservices inheriting from AnalyticsJob Server
Retrieves the status of a
specific job
8
Signals Job
POST: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/signals
CreateJob
Signals Microservice
Create a job to identify signals
9
Signal Results Job
GET: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/signals/<Job ID>/results
RetrieveResult
Signals
Microservice
Retrieve a result of a Signals job
10
Profile Job
POST: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/profiles
CreateJob
Profiling
Microservice
Creates a job to generate
  1. profiles.
11
Profile Result Job
GET: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/profiles/<Job ID>/results
RetrieveResult
Profiling
Micorservice
Retrieve the results of a
profiles job.
12
Train Model Job
POST: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/prediction
CreateJob
Training
Micorservice
Create a prediction
model job.
13
Train Model Result Job
GET: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/prediction/<Job ID>/results
RetrieveModel
Training
Microservice
Only retrieves the
PMML model. But if a
holdout for validation
was specified in the
CreateJob, a validation
job is auto-created and
  1. runs.
14
Scoring Job
POST: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/predictive_scores
BatchScore
Prediction
Microservice
Submit Predictive Scoring Job
15
Scoring Job Result
GET: http://<IP Address>:8080/1.0/datasets/<DataSet Name>/predictive_scores/<Job ID>/results
RetrieveResult
Prediction
Microservice
Retrieve results from prediction scoring jobs
Version history
Last update:
‎Dec 04, 2017 05:12 AM
Updated by:
Labels (3)
