The .net-sdk can be configured to emit very detailed debugging and diagnostic information to a log file during execution. The .net-sdk uses the standard .NET System.Diagnostic infrastructure for Logging, as such, all configuration of the .net-sdk logger is done via the standard .NET Logging configuration system.
The amount of information emitted can range from very low level Trace messages (the Verbose setting) to nothing at all (the Off setting). The “SourceLevels Enumeration” can be used to control how much information is written out to the log file. For reference, this is the
<add name="SourceSwitch" value="Information" /> element in the sample below.
Below is sample App.config file.
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<system.diagnostics>
<sources>
<source name="com.thingworx.common.utils.JSONUtilities" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.communications.client.TwApiWrapper" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.communications.client.BaseClient" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.communications.client.ConnectedThingClient" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.communications.client.things.contentloader.ContentLoaderVirtualThing" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.communications.client.things.filetransfer.FileTransferVirtualThing" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.communications.client.things.VirtualThing" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
<source name="com.thingworx.metadata.annotations.MetadataAnnotationParser" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
<listeners>
<add name="file" />
</listeners>
</source>
</sources>
<switches>
</switches>
<sharedListeners>
<add name="file" type="com.thingworx.common.logging.FixedFieldTraceListener, thingworx-dotnet-common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null" initializeData="false"/>
</sharedListeners>
<trace autoflush="true" indentsize="4" />
</system.diagnostics>
</configuration>
Hi ,
I have following two questions related to log.
1. Is there any way we can configure the log file name? or by any means we can provide the file name so that I can have control on the file name at least?
2. At present it generates only one log file and logs all information in it. Can we provide separate log file for each thing?
One more
3. Is there any file size limit for the log file?
