Popular questions on SOLR nodes in DSE
posipova
20-Turquoise
  • From the documentation, a SOLR node is only needed in case of using DataTables.  If the SOLR configuration field left blank, the extension will request to provide an input. Are SOLR nodes required or optional in order to use DSE with TW (in the hypothetical case of not using DataTables)?
     -- As for functionality of the Thingworx, a Solr node is not required. However, the extension does try to validate the configuration, and hence, at this point, a SOLR node is mandatory to properly configure the extension. This will be fixed in the future.
  • When there are 2 entries for addresses, one for a Cassandra Cluster and one for a Solr Cluster, are they the same Cluster, or different Clusters?
     -- They could be either. There can be one machine with SOLR enabled and using the same IP for both Cassandra and Solr. However, it's not recommend for production workloads. It would be perfectly fine for development or test environments.
  • In a Cluster, in order to have Solr and Cassandra nodes, use of Datacenters is required. Even if a Datacenter isn't explicitlydefined, a default install of DSE will create two data centers called "Cassandra" and "Solr" which is what would be seen see in the default "Cassandra Keyspace Settings" property in the configuration. If the user does create Datacenters with specific names then they will have to update the "Cassandra Keyspace Settings" property to reflect the same. I.e. replication = {'class':'NetworkTopologyStrategy', 'Cassandra':1, 'Solr':1} The number in front (1 being the default) represents the replication factor (https://docs.datastax.com/en/cql/3.1/cql/cql_using/update_ks_rf_t.html) depending on the number of nodes in each data center
0 REPLIES 0
