When you install Thingworx with PostgreSQL, you can't import the "PostgreSQL" extension because of the conflict of a library file.
So, here is a sample "MetaData.xml" file. You can zip this file and simply import it into your Thingworx so that you can have a thing template for "PostgreSQL" database.
<Entities>
<ExtensionPackages>
<ExtensionPackage name="PostgreSQL_ExtensionPackage"
description="PostgreSQL JDBC Extension"
vendor="ThingWorx Customer Service"
packageVersion="1.0"
minimumThingWorxVersion="4.0.0">
</ExtensionPackage>
</ExtensionPackages>
<ThingTemplates>
<ThingTemplate baseThingTemplate="Database" description="PostgreSQL Server" documentationContent="" effectiveThingPackage="" homeMashup="" lastModifiedDate="2015-11-28T11:40:35.355-05:00" name="PostgreSqlServer" tags="" thingPackage="">
<ThingShape description="" documentationContent="" lastModifiedDate="2015-11-28T11:40:35.355-05:00" name="" tags="">
<PropertyDefinitions/>
<ServiceDefinitions/>
<EventDefinitions/>
<ServiceImplementations/>
<ServiceMappings/>
<Subscriptions/>
</ThingShape>
<ImplementedShapes/>
<ConfigurationTables>
<ConfigurationTable description="" isMultiRow="false" name="ConnectionInfo">
<DataShape>
<FieldDefinitions>
<FieldDefinition aspect.defaultValue="5.0" baseType="NUMBER" description="Maximum number of connections in the pool" name="maxConnections" ordinal="0"/>
<FieldDefinition aspect.defaultValue="jdbc" baseType="STRING" description="jDBCConnectionURL" name="jDBCConnectionURL" ordinal="0"/>
<FieldDefinition aspect.defaultValue="SELECT NOW()" baseType="STRING" description="Connection validation string" name="connectionValidationString" ordinal="0"/>
<FieldDefinition aspect.defaultValue="org.postgresql.Driver" baseType="STRING" description="jDBCDriverClass" name="jDBCDriverClass" ordinal="0"/>
<FieldDefinition baseType="STRING" description="Database user name" name="userName" ordinal="0"/>
<FieldDefinition baseType="PASSWORD" description="Database password" name="password" ordinal="0"/>
</FieldDefinitions>
</DataShape>
<Rows>
<Row>
<jDBCConnectionURL><![CDATA[jdbc:postgresql://localhost:5432/demo]]></jDBCConnectionURL>
<maxConnections>100.0</maxConnections>
<connectionValidationString><![CDATA[SELECT NOW()]]></connectionValidationString>
<jDBCDriverClass><![CDATA[org.postgresql.Driver]]></jDBCDriverClass>
<userName />
<password />
</Row>
</Rows>
</ConfigurationTable>
<ConfigurationTable description="" isMultiRow="false" name="ConnectionMonitoring">
<DataShape>
<FieldDefinitions>
<FieldDefinition aspect.defaultValue="1.0" baseType="NUMBER" description="Number of retries" name="numberOfRetries" ordinal="0"/>
<FieldDefinition aspect.defaultValue="2000.0" baseType="NUMBER" description="Retry delay in milliseconds" name="retryDelay" ordinal="0"/>
<FieldDefinition aspect.defaultValue="false" baseType="BOOLEAN" description="Enable connection monitoring" name="enableMonitor" ordinal="0"/>
<FieldDefinition aspect.defaultValue="30000.0" baseType="NUMBER" description="Monitor rate in milliseconds" name="connectionMonitorRate" ordinal="0"/>
</FieldDefinitions>
</DataShape>
<Rows>
<Row>
<numberOfRetries>1.0</numberOfRetries>
<retryDelay>2000.0</retryDelay>
<enableMonitor>false</enableMonitor>
<connectionMonitorRate>3000.0</connectionMonitorRate>
</Row>
</Rows>
</ConfigurationTables>
<avatar/>
<DesignTimePermissions>
<Create/>
<Read/>
<Update/>
<Delete/>
<Metadata/>
</DesignTimePermissions>
<RunTimePermissions/>
<InstanceDesignTimePermissions>
<Create/>
<Read/>
<Update/>
<Delete/>
<Metadata/>
</InstanceDesignTimePermissions>
<InstanceRunTimePermissions/>
</ThingTemplate>
</ThingTemplates>
</Entities>
