ThingWorx 7.4 introduces a new licensing system. A license file (license.bin) needs to be placed in the ThingworxPlatform folder. A new license file is also required if you upgrade from 7.4 to a major or minor release (not service pack-level releases). For example:
• If you are using version 7.3, a license is not required.
• If you upgrade from version 7.4.1 to version 7.4.2, a license upgrade is not required.
• If you upgrade from version 7.4.3 to version 7.5.2, a license upgrade is required.
Refer to the Installing ThingWorx 7.4 guide or Upgrading ThingWorx 7.4 guide for detailed process steps.
A new Licensing Subsystem is now available.
Licensing subsystem services include:
-AcquireLicense– service allows for retrieval of feature entitlements in license.bin, used when new license dropped in folder (no need to instance restart)
–GetCurrentLicenseInfo – returns info on current license file
–GetRemainingDaysInLicense –used for trial editions
–GetLicenseUsageData – returns nformation about user’s license usage
–PurgeLicenseUsageData –deletes the license usage data that is two years and older
Useful information.
Thanks.
How we can check License details for ThingWorx version 7.1.2-b50
License concept has been introduced in 7.4
Thank you Polina Osipova
Can you please reference how licensing is handled in version 7.3? What I mean if there is a limitataion for user creation or users using the platform at the same time? the same with devices?
Please note 7.3 is no longer supported.
The concept of licensing (and, therefore, limitations) was introduced in 7.4.
