Recursive Network Traverse service
eliotlandrum
Amethyst
For a recent project, I was needing to find all of the children in a Network Hierarchy of a particular template type... so I put together a little script that I thought I'd share. Maybe this will be useful to others as well.
In my situation, this script lived in the Location template. This was useful so that I could find all the Sensor Things under any particular node, no matter how deep they are.
For example, given a network like this:
  • Location 1
    • Sensor 1
    • Location 1A
      • Sensor 2
      • Sensor 3
      • Location 1AA
        • Sensor 4
    • Location 1B
      • Sensor 5
If you run this service in Location 1, you'll get an InfoTable with these Things:
  • Sensor 1
  • Sensor 2
  • Sensor 3
  • Sensor 4
  • Sensor 5
From Location 1A:
  • Sensor 2
  • Sensor 3
  • Sensor 4
From Location 1AA:
  • Sensor 4
From Location 1B:
  • Sensor 5
For this service, these are the inputs/outputs:
  • Inputs: none
  • Output: InfoTable of type NetworkConnection
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(AlertSummary)
let result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
    infoTableName : "InfoTable",
    dataShapeName : "NetworkConnection"
// since the hierarchy could contain locations or sensors, need to recursively loop down to get all the sensors
function findChildrenSensors(thingName) {
	let childrenThings =  Networks["Hierarchy_NW"].GetChildConnections({
		name: thingName /* STRING */
    for each (var row in childrenThings.rows) {
        // row.to has the name of the child Thing
        if (Things[row.to].IsDerivedFromTemplate({thingTemplateName: "Location_TT"})) {
            findChildrenSensors(row.to);
        } else if (Things[row.to].IsDerivedFromTemplate({thingTemplateName: "Sensor_TT"})) {
            result.AddRow(row);
findChildrenSensors(me.name);
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
