ThingWorx 7.4 | ThingWorx 8.0 | ThingWorx 8.1 |
Installation Guide | Installation Guide | Installation Guide |
In the Java Options field, add the following to the end of the options field: -Dserver -Dd64 -XX:+UseG1GC -Dfile.encoding=UTF-8 -Djava.library.path=<path to Tomcat>\webapps\Thingworx\WEB-INF\extensions | ||
Place the license.bin file in your ThingworxPlatform folder | Obtain the license.bin file from the PTC Support site: a. Log into the PTC Support site. b. Click Manage Licenses. c. Click PTC ThingWorx>PTC Licensing Tool. d. Click Download. | Obtain your license Activation ID(s). Activation IDs are provided to new customers in the entitlement letter. Existing customers can visit the PTC Support site to obtain. |
Rename the file to license.bin and place it in the ThingworxPlatform folder | Open the platform-settings.json file and add the following inside the "PlatformSettingsConfig": "LicensingConnectionSettings":{ "username”:”PTC Support site user name", "password”:”PTC Support site password", "activationIds":"XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX, XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX" } | |
NOTE: You must have an Activation ID to ensure your license is current. Multiple IDs must be separated with a comma. |
Simple example for platform-settings.json:
"PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
"password": "password",
"username": "twadmin"
"PlatformSettingsConfig": {
"LicensingConnectionSettings": {
"username":"usernameForPTC",
"password":"password",
"activationIds":"activationIDsuppliedhere"
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
