Resolving a license error that prevents creating new entities
Opal
Error: Exception: JavaException: java.lang.Exception: Import Failed: License is not available for Product: null Feature: twx_things
Possible root cause: editing web.xml without further restart of the platform. In result, the product name does not pick up and the license path drops while the composer is still running,
Fix: Go to LicensingSubsystem -> Services and run the AcquireLicense service.
IF the issue does not get resolved, please contact the Support team, attaching your license.bin to the ticket.
3 REPLIES 3
Highlighted
Re: Resolving a license error that prevents creating new entities
After running AquireLicense, there is need of Tomcat restart to stop error showing in the future.
I am getting the following error -
"save failed, status: Internal Server Error message: Import Failed: License is not available for Product: null Feature: twx_things"
I restarted the tomcat but then also the is not resovled.
In this case, please contact someone from PTC Licensing to check your license file.
Best regards,
Raluca Edu
