SAPODataConnector hands-on (8.0)
smainente
In this blog I will be testing the SAPODataConnector using the SAP Gateway - Demo Consumption System.
Overview
The SAPODataConnector enables the connection to the SAP Netweaver Gateway through the ODdata specification. It is a specialized implementation of the ODataConnector. See Integration Connectors for documentation.
It relies on three components :
    • Integration Runtime : microservice that runs outside of ThingWorx and has to be deployed separately, it uses Web Socket to communicate with the ThingWorx platform (similar to EMS).
    • Integration Subsystem : available by default since 7.4 (not extension needed)
    • Integration Connector : SAPODataConnector available by default in 8.0 (not extension needed)
ThingWorx can use OAuth to access SAP, but in this blog I will just use basic authentication.
SAP Netweaver Gateway Demo system registration
1. Create an account on the Gateway Demo system (credentials to be used on the connector are sent by email)
2. Verify that the account has access to the basic OData sample service : https://sapes4.sapdevcenter.com/sap/opu/odata/IWBEP/GWSAMPLE_BASIC/
Integration Runtime microservice setup
1. Follow WindchillSwaggerConnector hands-on (7.4) - Integration Runtime microservice setup
Note: Only one Integration Runtime instance is required for all your Integration Connectors (Multiple instances are supported for High Availability and scale).
SAPODataConnector setup
Use the New Composer UI (some setting, such as API maps, are not available in the ThingWorx legacy composer)
1. Create a DataShape that is used to map the attributes being retrieved from SAP
    • SAPObjectDS : Id (STRING), Name (STRING), Price (NUMBER)
2. Create a Thing named TestSAPConnector that uses SAPODataConnector as thing template
3. Setup the SAP Netweaver Gateway connection under TestSAPConnector > Configuration
    • Generic Connector Connection Settings
      • Authentication Type = fixed
    • HTTP Connector Connection Settings
      • Username = <SAP Gateway user>
      • Password = < SAP Gateway pwd>
      • Base URL : https://sapes4.sapdevcenter.com/sap
      • Relative URL : /opu/odata/IWBEP/GWSAMPLE_BASIC/
      • Connection URL : /opu/odata/IWBEP/GWSAMPLE_BASIC/$metadata
4. Create the API maps and service under TestSAPConnector > API Maps (New Composer only)
    • Mapping ID : sap
    • EndPoint : getProductSet
    • Select DataShape : SAPObjectDS (created at step 1) and map the following attributes :
      • Name <- Name
      • Id <- ProductID
      • Price <- Price
    • Pick "Create a Service from this mapping"
Testing our Connector
Test the TestSAPConnector::getProductSet service (keep all the input parameters blank)
8 REPLIES 8
Great tool and great cheat sheet for this functionality. Same method works for the WindchillSwaggerConnector!!
Hi @smainente,
I'm trying this tutorial on Thingworx 8.0.1-b39. I have a SAP Gateway - Demo System (ES5) and my account have access to "https://sapes5.sapdevcenter.com/sap/opu/odata/IWBEP/GWSAMPLE_BASIC/". I have the integration runtime properly configured and running.
In Step 3 the following are the parameters i have given:
      • Base URL : https://sapes5.sapdevcenter.com/sap
The following are the erros i observed :
  • ValidateConnection
    Status Message ConnectorTemplate
    Failed
    Check logs for more details SAPODataConnector
  • GetEndpointList
    [context: com.thingworx.webservices.context.HttpExecutionContext@52e3b401][message: Unable to Invoke Service GetProductSet on ptc-SAP-OData-connector : Your route exchange has failed.  Resource Error [Connect to sapes5.sapdevcenter.com:443 [sapes5.sapdevcenter.com/155.56.38.41] failed: Connection timed out: connect]]
I'm suspecting the error is with this port sapes5.sapdevcenter.com/155.56.38.41 because i tested this URL ("https://sapes5.sapdevcenter.com/155.56.38.41") in the browser and it returned "HTTP 404 - Not found" page.
Could you please point out where i might be going wrong.
Reagrds,
Saran
Hi @smainente,
I have found the root cause for this issue. It seems our internal network was blocking the port since i'm trying out with a external SAP system.
I connected to an external network and tried the same and got positive connection for the OData connector.
Saran
BP_9517166
(To:SaranKarthick)
Hi @smainente/SaranKarthick,
I'm trying to connect to the demo Gateway but I'm getting Unable to Invoke Service : No Integration Runtime Connected, Contact Administrator for Further Information on clicking (+) new APIMApping.
the following are the parameters I have given:
      • Relative URL : /sap/opu/odata/IWBEP/GWSAMPLE_BASIC/
    Failed
  • GetEndpointList
I'm able to login to the sap demo gateway, https://sapes5.sapdevcenter.com/sap/bc/gui/sap/its/webgui.
Could you please let me know how can I fix this and connect to SAP.
Rocko
(To:BP_9517166)
Do you have the Integration Runtime, mentioned in the first post, running?
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FComposer%2FInteg...
EloyHz
(To:smainente)
Is it possible to add language information for the connector?
i.e by adding query parameter?
  • ?sap-language=DE
Thanks for the detailed information.
Followed this link for setting up account in demo system
https://developers.sap.com/tutorials/gateway-demo-signup.html
Also, in my case the URL for OData is
Can we set up integration runtime for demo system?
I am trying to download, however it is asking for customer id.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
