Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Send sensor data to ThingWorx through Azure using MXChip IoT DevKit
No ratings
The purpose of this document is to see how you can setup an MXChip IoT DevKit and also how send the readings of this microprocessor to ThingWorx through an Azure cloud server. You will also learn how to view the values that are being sent.
