ThingWorx Analytics 8.0/8.1 - Installing using the Linux Docker-based installer on CentOS 7
No ratings
Preface
This guide applies to a clean installation of the CentOS 7 Minimal distribution. This is labeled as "Minimal ISO" on the CentOS.org website and the filename of the iso image used to install the operating system will resemble "CentOS-7-x86_64-Minimal-1611.iso." The machine used in this guide was a virtual machine created using Oracle VirtualBox but the same steps should apply to any machine with a clean CentOS 7 Minimal install. It is however possible that some installations may encounter slight variations due to hardware configurations.
Before starting
Unzip the downloaded "MED-..._ThingWorx-Analytics-Server-Linux-Standalone-8-0-0.zip".  Inside the unzipped directory you will find a file called "ThingWorxAnalyticsServer-8.0.0-linux-x64-installer.run". Before running step number 10, upload that file to your CentOS machine using a SFTP SCP tool of your choice.
Configuration and installation steps
Step 1: Install Docker with the following commands (these steps are presented at https://docs.docker.com/engine/installation/linux/docker-ce/centos/#install-using-the-repository😞
yum install -y yum-utils device-mapper-persistent-data lvm2
yum-config-manager --add-repo https://download.docker.com/linux/centos/docker-ce.repo
yum makecache fast
yum -y install docker-ce
Step 2: Create a group called docker (If this command reports the group already exists, that is ok. You can move to the next step):
groupadd docker
Step 3: Add your non-root user to the docker group, in this example my non-root user is called "thingworx", please replace with the correct username:
usermod -aG docker thingworx
Step 4: Start the Docker service and enable it to auto start after reboot:
systemctl start docker
systemctl enable docker
Step 5: Verify that docker is working:
docker ps
Step 6: After running the above command you should see a single line output that resembles the following:
"CONTAINER ID        IMAGE              COMMAND            CREATED            STATUS              PORTS              NAMES"
Step 7: Disable selinux with the two following commands. Note by doing this you will want to make sure if this is a public facing server that you take appropriate security measures to lock down the system.
setenforce 0
sed -i -e 's/SELINUX=enforcing/SELINUX=disabled/' /etc/sysconfig/selinux
Step 8: Set the hostname of your machine to something otherthan the default which is "localhost.localdomain".  In this case I am using the name "centos", this can be replaced with a name of your choosing:
hostname centos
echo "centos" > /etc/hostname
Step 9: Allow traffic through the default CentOS firewall.  Note that in a production environment, the firewall should be configured more granular to allow incoming traffic to only the required ports (5432, 2181 and 8080). Please refer to CentOS documentation and consult security best practices within your organization for more information. The following commands will completely disable the CentOS firewall.
systemctl disable firewalld
systemctl stop firewalld
Step 10: Ensure the ThingWorx Analytics Server installer is executable then run the installer. You may have to change to the directory where the installer was uploaded to the machine, in this case I have it in the home directory of the user named thingworx.  Please replace that path with the correct path for your machine.  Note below are 3 separate commands.
cd /home/thingworx
chmod +x ThingWorxAnalyticsServer-8.0.0-linux-x64-installer.run
./ThingWorxAnalyticsServer-8.0.0-linux-x64-installer.run
Step 11: Verify that the ThingWorx Analytics Server installation is successful. Note that it may take a few minutes for the system to become available. Retry the command after a few minutes if an error is initially encountered.
curl http://127.0.0.1:8080/analytics/1.0/about/versioninfo
NOTE: The response from the above command should resemble the following: {"implementationVersion":"8.0.0"}
Comments
Great document.
But when I restart the VM, the containers don't run automatically, i.e. I have to run
     docker start community_postgres zookeeper gridworker1 analytics
manually.
How would I run this automatically on machine restart?
Roman,
You can set the auto start using the following command:
sudo /opt/ThingWorxAnalyticsServer/launcher/launcher -option=start -label=TAS
You can confirm that the label TAS is the correct one with the command:
sudo docker ps -a --format="table {{.ID}}\t{{.Labels}}\t{{.Image}}"
For reference, we have an article on the knowledge base that contains this information, that can be found here
Neel
There is an installer for Docker CE on AWS that sets up a Managed Docker env on AWS.
Neel, could you help me run the Foundation Docker installer in AWS? We are a big TWX partner and could use your help if you work for TWX.
Eric,
I am with the Analytics group, but they have a technical blog similar to mine for a Foundation installation, which can be viewed here
Neel
Version history
Last update:
‎Aug 31, 2017 10:35 AM
Updated by:
Labels (1)
