ThingWorx Solution Central now available!
Alexandrite
After months of development, hours of user interviews and countless coffees, ThingWorx Solution Central is here!
I posted a few weeks ago introducing the new cloud solution management portal, but just as a reminder, ThingWorx Solution Central is a brand-new set of cloud services offered to help you more efficiently manage and deploy your solutions—ow ow!
ThingWorx Solution Central automatically identifies and packages up your dependencies so you can slash your time to deploy. Once you develop your solution in ThingWorx (using the Projects feature), ThingWorx Solution Central will then automatically package up all the artifacts and dependencies required for your solution to run, and then you can publish your “package” up to the cloud, where it will be ready to be deployed to your specified environment(s).
Ready to get started? Request access to ThingWorx Solution Central here and you’ll be on your way to easier solution deployments in no time.
And if you happen to run into any trouble, see the ThingWorx Solution Central Help Center.
Happy deploying!
Stay connected,
Kaya
Re: ThingWorx Solution Central now available!
Hi Kaya - I work for Rockwell who are a partner of PTC around Thingworx. Are there are any publically available presentations on this?
Tags (1)
Hi @ogcorf74,
You can check out this post and view our LiveWorx presentation from this summer!
Stay connected,
Kaya
