Upload PMML to Thingworx Analytics
SOLVED
Amethyst
Here is a tutorial to explain the process of uploading a PMML file from an external system to Thingworx Analytics. The tutorial steps are explained in the attached PDF and all referenced files can be found in the attached ZIP.
1 ACCEPTED SOLUTION
Re: Upload PMML to Thingworx Analytics
Here is an updated version of the PDF and XML with some additional troubleshooting.
