This script dumps all the alarms for a model or asset to JSON.
Parameters (one or the other must be provided):
import com.axeda.common.sdk.id.Identifier
import com.axeda.drm.sdk.Context
import com.axeda.drm.sdk.audit.AuditCategory
import com.axeda.drm.sdk.audit.AuditMessage
import com.axeda.drm.sdk.scripto.Request
import groovy.json.*
import net.sf.json.JSONObject
import java.net.URLDecoder
import static com.axeda.sdk.v2.dsl.Bridges.*
import com.axeda.services.v2.CustomObjectCriteria
import com.axeda.services.v2.CustomObjectType
import com.axeda.services.v2.ExecutionResult
import com.axeda.services.v2.ExtendedMap
import com.axeda.drm.sdk.device.Model
import com.axeda.drm.sdk.device.ModelFinder
import com.axeda.drm.sdk.device.DeviceFinder
import com.axeda.services.v2.ModelCriteria
import com.axeda.services.v2.ModelType
import com.axeda.services.v2.FindModelResult
import com.axeda.services.v2.AssetCriteria
import com.axeda.services.v2.FindAssetResult
import com.axeda.services.v2.AlarmCriteria
import com.axeda.sdk.v2.bridge.MobileLocationBridge
import com.axeda.drm.sdk.mobilelocation.MobileLocationFinder
import com.axeda.drm.sdk.mobilelocation.CurrentMobileLocationFinder
import com.axeda.drm.sdk.data.AlarmState
import com.axeda.drm.sdk.data.AlarmFinder
import com.axeda.platform.sdk.v1.services.ServiceFactory
import com.axeda.drm.sdk.data.CurrentDataFinder
import com.axeda.drm.sdk.device.DataItem
import com.axeda.drm.sdk.data.HistoricalDataFinder
import com.axeda.drm.sdk.data.DataValue
import com.axeda.drm.sdk.data.DataValueList
import com.axeda.platform.sdk.v1.services.extobject.ExtendedObjectSearchCriteria
import com.axeda.common.date.DateRange
import com.axeda.common.date.ExplicitDateRange
* GetModel_Or_Asset_Alarms.groovy
* Returns assets with organizations, alarms, and current mobile location.
* @params
* modelName (OPTIONAL) Str - the name of the model to retrieve assets
* assetId (OPTIONAL) Long - the id of the asset - one of the two is REQUIRED
* @author sara streeter <sstreeter@axeda.com>
* initialize our global variables
* json = the contents of our response
* infoString = a stringBuilder used to collect debug information during the script
* contentType = the content type we will return
* scriptname = The name of this Script, used in multiple places
def json = new groovy.json.JsonBuilder()
def infoString = new StringBuilder()
def contentType = "application/json"
def scriptName = "GetModel_Or_Asset_Alarms.groovy"
def root = [:]
def timings = [:]
timings.dataItemList = 0
timings.currentdata = 0
timings.histdata = 0
timings.wholescript = 0
timings.alarms = 0
timings.loop = 0
timings.filter = 0
timings.devices = 0
timings.geocode = 0
wholestart = System.currentTimeMillis()
final def Context CONTEXT = Context.getSDKContext()
def deviceList
List<Device> devices
try {
/* BUSINESS LOGIC GOES HERE */
def modelName = Request.parameters.modelName
def assetId
def alarms
AlarmFinder alarmFinder = new AlarmFinder(CONTEXT)
if (Request.parameters.assetId != null && Request.parameters.assetId != ""){
assetId = Request.parameters.assetId
DeviceFinder deviceFinder = new DeviceFinder(CONTEXT, new Identifier(assetId as Long));
def device = deviceFinder.find()
if (device){
alarmFinder.setDevice(device)
modelName = device.model.name
else if (modelName){
try{
modelName = new URLDecoder().decode(modelName)
catch(e){ logger.info(e.localizedMessage) }
if (modelName != null && modelName !=""){
ModelFinder modelFinder = new ModelFinder(CONTEXT)
modelFinder.setName(modelName)
Model model = modelFinder.find()
if (model){
modelName = model?.name
alarmFinder.setModel(model)
alarms = alarmFinder.findAll()
// build the json from the models
root = [
"result": [
"model": modelName,
"assetId": assetId,
"alarms":alarms?.inject([]){ aList, alarm ->
aList << [
"deviceId": alarm.device?.id?.value,
"deviceName": alarm.device.name,
"deviceSerial": alarm.device.serialNumber,
"name": alarm.name,
"id": alarm.id.value,
"state": alarm.state.name,
"description": alarm.description,
"severity": alarm.severity,
"timestamp": alarm.date.time
aList
/* BUSINESS LOGIC ENDS HERE */
} catch (Exception e) {
def errorCode = "123456"
processException(scriptName,json,e,errorCode)
finally {
timings.wholescript = System.currentTimeMillis() - wholestart
root += [params: Request.parameters]
root += [timings: timings]
return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(root).toString(2)]
* ACTIVE CODE ENDS HERE
* HELPER METHODS START BELOW
* Wrap-up the response in our standard return map
* @param contentType The global contentType variable
* @param response The contents of the response (String ONLY)
private def createReturnMap(String contentType, String response) {
return ["Content-Type": contentType,"Content":response]
Processes the contents of an Exception and add it to the Errors collection
@param json The markup builder
private def processException(String scriptName, JsonBuilder json, Exception e, String code) {
// catch the exception output
def logStringWriter = new StringWriter()
e.printStackTrace(new PrintWriter(logStringWriter))
logger.error("Exception occurred in ${scriptName}: ${logStringWriter.toString()}")
Construct the error response
- errorCode Will be an element from an agreed upon enum
- errorMessage The text of the exception
json.errors {
error {
errorCode "${code}"
message "[${scriptName}]: " + e.getMessage()
timestamp "${System.currentTimeMillis()}"
return json
Log a message. This will log a message and add it to info String
@param logger The injected logger
@param scriptName The name of the script being executed
@param info The infoString to append to
@param message The actual message to log
private def logMessage(def logger, String scriptName, StringBuilder info, String message) {
logger.info(message)
info.append(message+"\n")
Audit a message. This will store a message in the Audit log, based on the supplied category.
@param category The category for this audit message. One of: "scripting", "network", "device" or "data". Anything not recognized will be treated as "data".
@param message The actual message to audit
@param assetId If supplied, will associate the audit message with the asset at this ID
private def auditMessage(String category, String message, String assetId) {
AuditCategory auditCategory = null
switch (category) {
case "scripting":
auditCategory = AuditCategory.SCRIPTING;
break;
case "network":
auditCategory = AuditCategory.NETWORK;
break;
case "device":
auditCategory = AuditCategory.DEVICE_COMMUNICATION;
break;
default:
auditCategory = AuditCategory.DATA_MANAGEMENT;
break;
if (assetId == null) {
new AuditMessage(Context.create(),"com.axeda.drm.rules.functions.AuditLogAction",auditCategory,[message]).store()
} else {
new AuditMessage(Context.create(),"com.axeda.drm.rules.functions.AuditLogAction",auditCategory,[message],new Identifier(Long.valueOf(assetId))).store()
def findOrCreateExtendedMap(String name){
// should take a name of Extended Map and output an object of type Extended Map, if it outputs null we throw an Exception
def outcome = [:]
outcome.extendedMap
ExtendedMap extendedMap = extendedMapBridge.find(name)
if (!extendedMap){
extendedMap = new ExtendedMap(name: name)
extendedMapBridge.create(extendedMap)
if (extendedMap) {
ExecutionResult result = new ExecutionResult()
result.setSuccessful(true)
result.setTotalCount(1)
outcome.result = result
outcome.extendedMap = extendedMap
else {
result.setSuccessful(false)
return outcome
def retrieveModels(){
// retrieves the list populated by a separate script
def outcome = [:]
outcome.modelList
ModelCriteria modelCriteria = new ModelCriteria()
modelCriteria.type = ModelType.STANDALONE
FindModelResult modelResult = modelBridge.find(modelCriteria)
if (modelResult.models.size() > 0){
outcome.modelList = modelResult.models
else {
return outcome
def returnModelsWithAssets(List<com.axeda.services.v2.Model> modelList){
def outcome = [:]
outcome.modelList
outcome.message
if (!modelList || modelList?.size() ==0){
outcome.message = "returnModelsWithAssets: Model list was not supplied or was of size zero."
return outcome
DeviceFinder deviceFinder = new DeviceFinder(CONTEXT)
List<com.axeda.drm.sdk.device.Model> sortedList = modelList.inject([]){ target, amodel ->
modelFinder.setName(amodel.modelNumber)
com.axeda.drm.sdk.device.Model bmodel = modelFinder.find()
deviceFinder.setModel(bmodel)
def numAssets = deviceFinder.findAll().size()
if (numAssets > 0 ){
target << bmodel
target
}.sort{ amodel, bmodel -> amodel.name <=> bmodel.name}
if (sortedList.size() > 0){
outcome.modelList = sortedList
else {
return outcome
def addMapEntry(String mapName, String key, String value){
def outcome = [:]
outcome.key
outcome.value
ExecutionResult result = extendedMapBridge.append(mapName, key, value)
if (result.successful){
outcome.key = key
outcome.value = value
return outcome
