ThingWorx 9.3 is Here!
No ratings
As of Dec. 23, 2021, ThingWorx 9.3.0 is available for download and on Jan. 7, 2022, it will be available for Cloud Services.
What’s new in ThingWorx 9.3?
Composer and Mashup Builder
  • Enhanced ability to find entities, code references, and project dependencies with a new Referenced by report feature.
  • New Grid widget allows for improved visualization of row/columnar type data, with improved performance, styling, and configuration experiences.
  • Composer enhancements allow for faster configuration and application management in the areas of test execution and dynamic use of Master Mashups.
Analytics
  • New configuration parameters (binningStrategy and allowOverlap) available for profiles to tailor application of the algorithm to meet needs of domain use cases.
  • New option to utilize K-Fold cross validation to improve quality of predictive models created on limited data sets using industry standard technique.
  • Automate treatment of missing values to reduce data preparation before application of advanced analytics algorithms.
Foundation
  • Query performance improvements with indexing enables performance of quick “search” queries across thousands of connected assets and pre-filtering of query resultsets for better overall query performance.
  • Upgrade script improvements for logging, script execution and error handling which simplify the upgrade process.
Remote Access and Control
  • Improvements to Remote Access and Control includes Auto & Click to Launch capabilities that streamline the remote access startup process by starting the support application you need for you. New connectivity options enable user control and selection of local IP and Port addresses used in the session creation.
Software Content Management
  • Instructions can now be configured to execute either Synchronously or Asynchronously for a streamlined execution process. Added support for data migration of older, from the audit data table information into a format to the new audit database.
View release notes here and be sure to upgrade to 9.3!
Stay Connected,
Rachel
Comments
Hello. My name is Ainur. Can you provide me with a trial version of Thingworx Foundation along with the Mashup function?
Version history
Last update:
‎Dec 30, 2021 01:03 PM
Updated by:
Labels (1)
Tags (1)
