ThingWorx Foundation/ThingWorx Analytics Video Guide
No ratings
Build a Predictive Analytics Model - Video Guide
This project will introduce ThingWorx Analytics Builder via a convenient video-guide. Following the steps in this video, you will create an analytical model, and then refine it based on further information from the Analytics platform. We will teach you how to determine whether or not a model is accurate and how you can optimize both your data inputs and the model itself.
This video demonstrates the installation of Analytics Server with SSL protections enabled. It includes information about generating the necessary certificates and truststores to enable SSL for each component that connects with the server.
This video demonstrates the Platform Analytics installation with SSL protections enabled. It provides information about generating the necessary certificates and truststores to enable SSL for all connected components, including RabbitMQ and Flink.
Watch this video to learn how to add a Toolbar widget to a mashup in ThingWorx. You'll learn how to define actions using a data service and create bindings to control and configure a Grid widget.
This video demonstrates the ThingWorx SSO login procedure using Azure AD. The login procedure is shown from a user point of view. Then a behind the scenes view looks at the design in ThingWorx Composer.
Watch this video to learn how to create a mashup layout that uses a Menu Bar widget for navigation. You'll learn how to create a layout, define menu items, and configure the widget.
This video provides a walk-through of the steps required to set up SSO for ThingWorx in an environment where AD FS is both the CAS and the IdP. The focus is on the AD FS setup steps.
Following the steps in this video-guide, you will learn how to use the ThingWorx Mashup Builder tool to create a Graphical User Interface (GUI) for your IoT Application. We will teach you how to rapidly create and update a Mashup, which is a custom visualization built to display data from devices according to your application's business and technical requirement
Explore the ThingWorx Foundation Internet-of-Things application building platform in a convenient, instructional video guide format.
This session covers the most common and useful tips about how to correctly use Mashup builder, Widgets and Layouts – and what to avoid - to create applications with good principles of UI/UX and easier to maintain.
The industry’s most complete IIoT platform just got better. Loaded with a full range of new and updated features and functionality, you can expect powerful platform capability enhancements across the board.
You can’t implement IIoT solutions if you can’t connect to your assets, but in complex environments connectivity can seem like an insurmountable challenge. ThingWorx makes it easy to establish standardized connectivity, so you can create a secure, single-source for accessing industrial data across your IT and OT systems
Watch the following video on how to add the Bar Chart widget to a mashup and configure basic widget properties.
Watch the this video to learn how to add the Button widget to a mashup and use its Clicked event to trigger data services.
Watch the this video to learn how to add the Line Chart widget to a mashup and bind a data source.
Create compelling, modern application user interfaces in ThingWorx with the latest enhancements to our Mashup visualization platform - Collection and Custom CSS. In this webinar with IoT application designer Gabriel Bucur, we'll show how the new Collection widget makes it easy to replicate visual content in your UI for menu systems, dashboards, tables, and more.
Native testing is an often-overlooked aspect of edge application development. This session shares how to perform thorough testing before you push your application into live production.
Adopting a predictive maintenance strategy for the first time can often feel daunting, but it doesn't have to. Learn how ThingWorx can be used to leverage edge devices and turn monitoring activity into action.
Designing Mashups takes time. Moreover, expanding upon a Mashup that was built for a small-scale application can get cumbersome.
Understanding access controls can be difficult. With the built-in security features and concepts in ThingWorx, you can easily give your devices access on-demand.
The Store and Forward feature within ThingWorx Industrial Connectivity assures users that critical data collected at the edge won't get lost during an outage.
Version history
Last update:
‎Oct 14, 2022 10:25 AM
Updated by:
Labels (2)
Contributors
