Aggregator, how can i configure?
rodolfocorral
9-Granite
Hi, i have some devices under Kepware v5, i would like to connect to those and i saw that through aggregators that could be possible, what do i need to configure the aggregators?
Do i have to install something? is only configuration? i don't see a lot of information related to the setup.
Any document or answer would be appreciated.
Thanks!
Just log into the My Kepware portal, and there is a link on the right.
Hi, rodolfocorral
My understanding is that the Aggregator is simply a way to pull data in from third party OPC servers and push the data up to ThingWorx. Is there some reason not to connect your KEPServerEX, directly to ThingWorx?
Rob
The reason is because Kepware version is under 6.1, so is not compatible to connect directly.
Thanks for the follow-up, did you know that Kepware is running a promotion to allow all users to update to 6.5 for free?
Would you be able to take advantage of this offer and update then connect directly?
Rob
I had no idea of that promo, how could i get more info about it?
Sounds a good option!
