Is there a way to send out alerts from Kepware whenever a connected Modbus TCP/IP device disconnects?
For example, when these errors are shown:
Thank you!
You should look into the _Error tag from the _System tag group of the device.
I like this approach.
We are going to use the Advanced IoT Plugin to scan the "_System._Error" device tags.
If they are true, then there is a disconnection. If they are false, everything is working fine.
Thanks!
