Asset Inventory
ZS_11754397
2-Explorer
Asset Inventory
Does anyone know if there is a way to export the asset inventory from Kepserver?  Looking specifically for a list of the devices at a site with their name, IP and/or MAC address, and anything else we can get.  Would be interested in the API call as well if there is one.
You can export the JSON file and parse it . . .
@SlidingDownhill do you know if all of the info I mentioned is available?  Is it also available via API?
Mostly....
While we don't have an exact example, you could most likely modify this example script in the PTC Kepware GitHub that allows you to count objects through the API:
https://github.com/PTCInc/Kepware-Example-Scripts/tree/master/Config%20API/Count%20Channels%20and%20Devices
-Andy
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
