We are using KEPServerEX in one of our project setup(with services and connections). This setup should restart by itself when the server on which its running is restarted.
Among the other elements in the setup I need KEPServerEX also to start itself (running as an Administrator).
How do I configure this in Kepware.
Sri1
Hi @Sri1,
Here are some articles that I hope can help you with that :
- Starting KEPServerEX / ThingWorx Industrial Connectivity in Interactive mode automatically
Hi @Sri1,
Hi @Sri1.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
