From Derived Tags, we are getting negative values due to spikes in the signals; how can we avoid sending negative values from KepServerEx to Thingworx or any configuration that can be done from KepServerEx to avoid this or any change that can be done in the Remote Thing? Such that storing negative values on DataBase can be avoided.
Within the Derived Tag, you can use the Absolute qualifier:
Best regards,
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
Best regards,
Andy Servetas
