I have two OPC clients (both support DA and UA) which I would like to connect via an existing KepServer instance with OPC connectivity suite installed.
What is the best practice here to create/add the OPC tags to KepServer.
My initial thought of using simulated tags (without a simulation function) and connecting both OPC clients with the KepServer Simulation Driver works, but I am not sure if this is the best way for production environment.
Could you assist me on this?
Please see this article for reference:
https://www.ptc.com/en/support/article/CS320427
-Andy
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
-Andy
Andy Servetas
