I have 2 buttons in my mashup, "START" and "STOP" buttons. With these buttons I would like start and stop the data entry from Industrial Connectivity. Is it possible? If not, How can I program a simulate data in my thing "Temperature"? And with these buttons start and stop this simulation?
I am trying with one button and display bind through GetPropertyValues and the click event is working but I don´t know if I have to program a service, event, subscription...
Thank you in advance
BR,
Luis
Hello Luis,
Thank you for reaching out on the ThingWorx Developer Community.
My apologies on the delay in response on this matter. Were you able to find a solution for the initial question proposed?
When you say you would like to start and stop data entry from the Industrial Connectivity are you referring to connecting or disconnecting a Remote Thing?
If so, you should be able to accomplish this by connecting the EnableThing service to the START button and the DisableThing service to the STOP button.
Tyler Misner
ThingWorx Technical Support Engineer
Hello Luis,
Tyler Misner
Hi Tyler,
Yes,I referred to connecting or disconnecting a Remote Thing. I solved it but thank you for your answer anyway.
Luis
