I have a remote thing bound to Kepware in Thingworx. The data type is String in Kepware , it works well if I write number or english alphabet, however , if write chinese character then it become garbled in Kepware , please check the attached picture .
If I set chinese character in Kepware directly, then Thingworx can read it and display correctly. Only write has problem.
Any idea about it ?
Thingworx 8.5.2
Kepware: KEPServerEX 6
Sean
@zyuan1 ,
Thanks, I've created a ticket to Kepware and it's been confirmed to be a bug in Kepware 6.6, and the issue has been fixed in 6.8.
Sean
It's kind of like an encoding issue, you should create a Kepware case for it.
@zyuan1 ,
Sean
Hi @seanccc.
Glad you found the solution! Please mark your last post as the Accepted Solution for the benefit of others with the same issue.
--Sharon
