I connect Kepware 6.13 to our Siemens PLC by using OPC UA. But there is a problem that some of the messages are written in Chinese and when we try to monitor them on Kepware Quick Client, they are appeared as garbled.
Best Regards,
Nava
Similar issue - "Chinese characters become garbled are writing to Kepware from Thingworx": https://community.ptc.com/t5/Kepware/Chinese-characters-become-garbled-are-writing-to-Kepware-from/td-p/665995
Hello VladimirN,
Thank you so much for your comment. I checked the post that you shared, and found that this issue should be solved since Kepware6.8, but I am using Kepware6.13 and still found this issue. Do you know if there is any configuration that I should set in order to be able to activate this "reading Chinese" feature
Thank you,
Nava
@NT_10644172,
My name is Chris, and I am a Kepware Community Agent. I recommend open a Support Ticket with the Kepware team as I believe this issue will need Kepware Developer engagement. I will be able to monitor the support ticket and potentially update this original post with possible resolution. Here is a link to the login page where a support ticket can be opened:
*Chris
Thank you Chris,
I will ask our supplier to create the Ticket.
Best Regards,
Nava
