Q-series Mitsubishi PLC connected to two Kepservers. One is KEPServerEX v6.14.263.0 and another one is Thingworx Kepware Server v6.14.263.0.
I am receiving data from PLC in KEPServerEX v6.14.263.0 but not in Thingworx Kepware Server v6.14.263.0. all the channel and device configuration is same.
Communication is having TCP connection and port number is 10000 in mitsubishi PLC and same at server side.
earlier I was able to receive the data in both the servers.
How can it be resolved?
Greetings @GC_11210517,
I hope you're doing well.
I would request you kindly follow to the below steps to troubleshoot and resolve the problem:
For more details please refer to the steps outlined in this article CS278701.
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
I have already tried above mentioned troubleshooting points except point 2 but no result.
I don't want to Restart the Thingworx Kepware Server service since it is in production.
Hi @GC_11210517,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
I have already tried troubleshooting steps mentioned by @ntripathi except point 2 but no result.
No solution till yet.
Greetings @GC_11210517 ,
If the issue persists; I recommend opening a support ticket with the Kepware Technical Support team. Here is a link to the my kepware login page where a ticket can submitted:
