Hey ptc community,
for some testing I need to simulate some data. I was told that I can use the Keepserver for this. I found the options but I don´t know how I can connect the Keepserver to my local Thingworx and start to simulate data there.
I found this to start a simulation: https://community.ptc.com/t5/ThingWorx-Developers/How-do-I-simulate-random-tag-values-against-a-device-in-kepware/td-p/545582
And I created a simulator, but how can I make a connection?
Maybe someone did it before and can help me with my problem?
@Keffler I came across this guide which might be helpful for you.
Also, you may refer to these articles for more information:
https://www.ptc.com/en/support/article?n=CS279234
https://www.ptc.com/en/support/article?n=CS276903
Vibhuti
Vibhuti
@Keffler If your issue is resolved, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
