HI
I try to create a thing linked with the Kepware Server ....it was working really well with the trial version
but with the license is not working..
i created the industrial connection with Kepware and is working well
I can read all the tags from kepware with the Discover function of the industrial connection
I created a thing with the bind function but the new thing still alway disconnected
here the log
Im sure that someone can help me ...thank you
thanks for all the help
Just before trying the steps you sent me in link .....i decided to try the deployerkey instead of my own key
and is working well now .....to be honest its seems to be the same configuration...i dont know why !!!
@DP_9890933 : In the thing did you checked whether the 'industrial thing' property is set to your industrial connection?
Thanks for the help ...i really appreciate
here my connection ...look like ok
Just create again from scratch with simulate value between Kepware Server and ThingWorx fundation
and again the industrial connection is good but the thing still not connected
but why the signal is Unknown if im connected ?
@DP_9890933 : I suspect that legacy mode is enabled in you Kepware which might be causing this issue. Can you please disable it as KEPServerEX Project Properties > select the ThingWorx property group > set Legacy Mode to Disable.
HI
thanks again for your help
it seems that i dont have this option.....its the KepServerEx 6
@DP_9890933 : Can you please check the application key which you have provided in Kepware with which you are trying to connect to thingworx? Please check whether its not expired. I would also suggest to try connecting with an 'Administrator' app key.
HI
The expiration date is for 2025 and i just tried with the administrator key and its not working
Hello @DP_9890933
Based on the error you are getting I could find the following article and community post, Please try the troubleshooting steps mentioned
https://www.ptc.com/en/support/article/CS279741
Please let us know if this doesn't resolve the issue.
Om Dukiya
Hi, @DP_9890933 .
We encounter the same problem with you, but we can't find how to switch the Application Keys to DeployerKey.
Xiyan
How to create a DeployerKey?
