I need support in getting Atlas Copco Digital Torque Tool Controller PF6000 to Ignition through Kepware.
Can you please walk me through the steps ?
thanks
Use OPC UA protocol for connecting Kepware to the ignition, where Kepware will act as an OPC UA server and Ignition will be an OPC UA client.
Please follow the underlined steps mentioned in the article for the OPC UA connectivity:
https://www.ptc.com/en/support/article/CS298913
-Thank You
-Thank You
