Hi Has anyone been able to use a single Kepware Server, to interact with multiple Thingworx Servers? It would seem there is only a 1:1 relationship for this. (Using the KepwareEX extension)
Yes you are right, actually you can only connect one Kepware Server to one ThingWorx Server ( of course you can have as many Kepware Servers connectes to the same ThingWorx Server ).
