Not sure if what I want to do is possible, I can't find anything solid saying yes or no.
I am using Kepware now to log data to an SQL Database when a tag changes. I would also like it to create a CSV file at the same time automatically. Is this something that can be done inside Kepware? Tyring to keep everything in one place if possible.
Thanks!
You can do it using SSRS on your SQL side if you have that available
