I am trying to read,write data from EXCEL to kepserver by using DDE client. But I am getting communication quality as bad. I have made Run time process mode as "Interactive". when I am trying to connect runtime the below error is showing
"Configuration Connection attempt to runtime failed. | User = 'LAPTOP\PRASANTH KP', Reason = 'The specified account does not exist.'."
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS348789
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
