In the OPC Quick Client, Kepware has few default tags like data logger, system tags and scan mode and demotion tags apart from the tags that I create. What is the purpose of these tags? Is there any documentation to learn about these tags and its use?
Please provide some ideas.
Thanks in advance,
Shalini V.
@svisveswaraiya You can refer to Kepware documentation which has details about these tags however it might cover everything you need.
https://www.kepware.com/getattachment/5759d980-7641-42e8-b4fb-7293c835a2f9/kepserverex-manual.pdf
-Durgesh
-Durgesh
