Error Writing to KepServerEX Simulator with Node-red
MM_14203880
2-Explorer
I have no problem in reading Kepware simulator from address R0001 (which self incrementing) from node-red, but unable to write into address K0001 or S0001 in node-red. Any advice will be much appreciated ? The moment i started to write, the node-red exited!.
ns=2;s=SimulatorChannel.SimulatorDevice.MyWriteTag
MKhatri
(To:MM_14203880)
Greetings,
Ensure that tags K0001 and S0001 in Kepware are set to Read/Write under Client Access in tag properties. This allows Node-RED to perform write operations without crashing.
Mohit
If you can read from the KepServerEX Simulator but Node-RED crashes when writing, the issue is usually with the OPC UA node configuration or tag permissions. Here’s what you need to check:
  1. Tag Permissions in KepServerEX
    • Open your Simulator Channel → Device → Tag in KepServerEX.
    • Make sure the tag you’re trying to write to is configured as Read/Write, not Read-Only.
    • Test the write directly from KepServerEX Quick Client first. If that fails too, it’s a tag configuration issue.
  2. Node-RED OPC UA Write Node Setup
    • The Node-RED OPC UA “write” node should have the correct namespace and node ID. Example:
    • Double-check that this matches exactly with the tag path in KepServerEX (case-sensitive).
  3. Data Type Match
    • Node-RED must send a value of the same data type as defined in KepServerEX.
    • For example, if your tag is Int16, send a numeric value, not a string.
    • Mismatched types will cause the OPC UA client (Node-RED) to exit or fail.
  4. User Access Level
    • If you’re connecting with security policies enabled, ensure the user credentials have write access in KepServerEX.
    • Under Project Properties → OPC UA → Users and Permissions, verify the account used by Node-RED is allowed to write.
  5. Test Using UaExpert
    • Try writing to the same tag from UaExpert. If it works, the problem is in Node-RED configuration.
    • If it fails in UaExpert too, it’s definitely a KepServerEX tag or permission issue.
Once tag permissions, namespace, and data types are aligned, Node-RED will write successfully without exiting.
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
