Error code 10061 on two devices via modbus gateway.
LK_8978441
3-Newcomer
Hello PTC Community ,
Error description : Socket error occurred when connecting :  | Error 10061 , Details = No connection could be made because the target device has actively refused it.
Can anyone shed light on what's happening ?
Kepware Server version : 6.15
Best Regards
Troubled Customer.
Hello, Please take a look at the following article as it may help resolve your issue:
CS299048 - TCP Socket Connection Errors in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
